Zum Hauptinhalt wechseln
Dell Inspiron 15-7569 Battery Replacement
Was du brauchst
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: Schritt 2, Bild 1 von 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: Schritt 2, Bild 2 von 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S5-G4, Walkup Fall 2017 Mitglied von USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 6,157
