Einleitung
If your tablet's battery no longer holds a charge, this guided will show you how to replace it with a new one.
Was du brauchst
Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Use the plastic card to pry the battery away from the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
where can i buy a battery replacement? can it work without a battery?
