Zum Hauptinhalt wechseln
Acer Aspire V5-591G-75KE Wireless Card Replacement
Was du brauchst
  1. Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: Schritt 1, Bild 1 von 3 Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: Schritt 1, Bild 2 von 3 Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: Schritt 1, Bild 3 von 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 2, Bild 1 von 2 Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 3, Bild 1 von 2 Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 3, Bild 2 von 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 4, Bild 1 von 3 Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 4, Bild 2 von 3 Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 4, Bild 3 von 3
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Wireless Card Replacement, Wireless Card: Schritt 5, Bild 1 von 1
    • Locate the wireless card on the top left quadrant. It should have two antenna cables connected to it, one white and one black.
  6. Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • With a pair of blunt tweezers, firmly grasp each antenna head and detach it by lifting straight up.
    • The antenna cables are connected through small sockets. Small popping sounds when attaching and detaching the antennas are normal.
    • Note that the white cable connects on the top socket.
  7. Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 7, Bild 1 von 2 Acer Aspire V5-591G-75KE Wireless Card Replacement: Schritt 7, Bild 2 von 2
    • Using a Phillip Head size 1 screwdriver, remove the screw attaching the wireless card to the laptop frame.
    • To detach the wireless card, lift up slightly and pull away.
Abschluss
Tasier Hagler
428 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team S3-G5, Liner Fall 2017 Mitglied von UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,235
