Zum Hauptinhalt wechseln
Lenovo G50-80 80E5 Battery Replacement
  1. Lenovo G50-80 80E5 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Battery Replacement: Schritt 2, Bild 1 von 3 Lenovo G50-80 80E5 Battery Replacement: Schritt 2, Bild 2 von 3 Lenovo G50-80 80E5 Battery Replacement: Schritt 2, Bild 3 von 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Battery Replacement: Schritt 3, Bild 1 von 3 Lenovo G50-80 80E5 Battery Replacement: Schritt 3, Bild 2 von 3 Lenovo G50-80 80E5 Battery Replacement: Schritt 3, Bild 3 von 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Battery Replacement: Schritt 4, Bild 1 von 3 Lenovo G50-80 80E5 Battery Replacement: Schritt 4, Bild 2 von 3 Lenovo G50-80 80E5 Battery Replacement: Schritt 4, Bild 3 von 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Abigail Hood
387 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G6, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G6
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
I purchased a new battery. I think I have not put the new one correctly. It does not align right. The computer is working fine. But it does not charge until I place a couple of books under the battery case, to kind of keep it in place..
Ashish Nelson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 4,497
