Einleitung
If you device will not turn on, it may be due to a defective power supply. If there are issues with the power supply on the device, this guide is here to demonstrate how to replace it.
Was du brauchst
Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
Tilt the back of the top cover forward to remove from chassis.
Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
Tilt the board forward and lift up to remove from the chassis.
