Einleitung
Use this guide to replace the top motherboard on your device.
Was du brauchst
Flip speaker over so that the bottom is facing up.
Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
Using the screwdriver, unscrew three screws.
Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
Remove the two screws connecting the motherboard to the bottom cover of the speaker.
Remove the bottom cover.
Using your hands, grip and separate the soft plastic and the metal casing away from each other with some small force.
Lift up and look on the underside of the circuit board.
Using the plastic opening tool, pry open the wide clamp keeping a ribbon to the top circuit board. The top circuit board can now freely be removed from the device.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
12 Kommentare
Same here. My speaker had one circuit replacement on warranty but now need a second replacement and I not willing to pay half the price of a new speaker each a every year. Can you help please ?
My e-mail is fmtbmp@gmail.com
Hi, I need to buy the top and bottom circuit board and was wondering the same. Any help with where to purchase these would be appreciated,
Thanks, my email is fayclaybrook28@outlook.com
I am also looking for a top circuit board replacement. Where can I get one. michael@parsche.net
