Zum Hauptinhalt wechseln
Acer Aspire 4520-5464 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire 4520-5464 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 4520-5464 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Remove the seven 2mm Phillips #1 screws from the largest panel on the back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Hard Drive Replacement: Schritt 5, Bild 1 von 3 Acer Aspire 4520-5464 Hard Drive Replacement: Schritt 5, Bild 2 von 3 Acer Aspire 4520-5464 Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 0.5mm Phillips #1 black screws left of the Hard Drive.
    • Remove the two 0.5mm Phillips #1 silver on top of the Hard Drive.
    • Lift up and remove the hard drive bracket by the plastic tab on top of the hard drive.
  6. Acer Aspire 4520-5464 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the hard drive from the device.
Abschluss
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 828
