Einleitung
To complete this guide you will need patience and to work with a steady, gentle hand.
Was du brauchst
Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
Loosen the back cover by using a plastic opening tool all the way around the device.
Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
To remove the Wifi PCB wire lift up the hinged flap with your finger or with the aid of the spudger tool.
After the flap is lifted, pull the wire up out of the connector socket.
Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires.
Once the wires are removed the fan should be removed entirely.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Where do you purchase a replacement fan?
I was able to replace my fan without removing the battery (skip steps 5-8). Also able to skip steps 12 (Wifi PCB wire) and 13 (headphone jack wire) by carefully moving those wires out of the way while removing the fan. Note that when removing the heat sink, the the old thermal paste should be cleaned off and new paste applied (it may come on the new heat sink). The fan I bought on eBay was a C30 model with different heat sink, but I was able to swap the old heat sink onto the new fan. Final note when reassembling - the rubber footpads are NOT interchangeable. One has a small round hole and the other has a short slot.
