Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Remove the screws that secure the hard-drive assembly to the computer base.
Using the pull tab, disconnect the hard-drive cable from the system board.
Lift the hard-drive assembly off the computer base.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
Align the screw holes on the hard-drive assembly to the computer base.
Replace the screws that secure the hard-drive assembly to the computer base.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
