Zum Hauptinhalt wechseln
Dell Alienware 13 Hard Drive Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Dell Alienware 13 Hard Drive Replacement, WARNING: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Alienware 13 Hard Drive Replacement, Disconnecting Hard Drive Cable: Schritt 2, Bild 1 von 1
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  3. Dell Alienware 13 Hard Drive Replacement, Lifting Hard Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Alienware 13 Hard Drive Replacement, Removing Hard-Drive Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Alienware 13 Hard Drive Replacement, Lifting the Drive: Schritt 5, Bild 1 von 1
    • Lift the hard drive off the hard-drive bracket.
  6. Dell Alienware 13 Hard Drive Replacement, Disconnect Interposer: Schritt 6, Bild 1 von 1
    • Disconnect the interposer from the hard drive.
  7. Dell Alienware 13 Hard Drive Replacement, Connect the Interposter: Schritt 7, Bild 1 von 1
    • Connect the new interposer to the new hard drive.
  8. Dell Alienware 13 Hard Drive Replacement, Screw Holes: Schritt 8, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  9. Dell Alienware 13 Hard Drive Replacement, Screw Replacement: Schritt 9, Bild 1 von 1
    • Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
  10. Dell Alienware 13 Hard Drive Replacement, Align Screw Holes: Schritt 10, Bild 1 von 1
    • Align the screw holes on the hard-drive assembly to the computer base.
  11. Dell Alienware 13 Hard Drive Replacement, Replace the Screws: Schritt 11, Bild 1 von 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Dell Alienware 13 Hard Drive Replacement, Connect Drive: Schritt 12, Bild 1 von 1
    • Connect the hard-drive cable to the system board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 117
