Einleitung
Step-by-step guide to replace the motherboard in a Asus VivoTab RT TF600T.
Was du brauchst
Remove the tablet from the attached keyboard.
To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
Rotate the device 180°, and use a PH000 screwdriver to remove the two 1.59 mm screws at the bottom.
Insert a plastic opening tool into the bottom right corner, and gently start to pry off the screen.
Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
Now that the frame is separated, lift the screen assembly partially away from the motherboard.
Before disconnecting the display cables, turn off the switch labeled DIP; this switch is used to de-energize the system.
Remove the yellow tape that secures the digitizer and LCD screen ZIF connectors.
After removing the yellow tape, use a plastic opening tool to lift the two digitizer ZIF connector tabs; pull the ribbon cable free.
Use a plastic opening too to lift the LCD screen ZIF connector; pull the ribbon cable free.
Remove the two 0.79mm screws from the charging port with the Phillips #00 screwdriver.
Place the plastic opening tool behind the charging port, closest to the outer edge of the device.
Gently pry the charging port away from the frame.
Use a nylon spudger to help carefully pry the motherboard from the back panel.
Once the motherboard is relieved from the glue, use your hand to lift the motherboard up and to the opposite end of the back panel.
Use a plastic opening tool to lift and release the battery ZIF connector; gently pull the ribbon cable free.
Remove the motherboard.
