Einleitung
Use this guide to disassemble a Braun hld6 hairdryer or to gain access to malfunctioning parts that need to be replaced.
Was du brauchst
Take out the two 32.3 mm Phillips #1 screws from the outside.
Take out the one 6.0 mm Phillips #1 screw.
Take out the 14.6 mm Flathead screws that hold the power cord in place.
Take out the 18.2 mm Flathead screws that hold the buttons in place.
Take out the 27.1 mm Flathead screws that keep the motor in place.
Loosen the 2 flathead screws in the terminal block closest to the power cord.
Pull out the power cord.
Loosen the flathead screws and remove the wires from the button holder. Remove the button holders. When you unscrew the wire opposite to where the yellow wire is connected, you can slide the button off of the middle wire connected to the motor.
