Zum Hauptinhalt wechseln
Autosampler Reset for Node Triggered Sampling (For Old & New Versions)
Was du brauchst
  1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: Schritt 1, Bild 1 von 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: Schritt 1, Bild 2 von 2
    • To enable manual mode, flip the switch to "Manual Mode"
    • LCD screen will turn on
  2. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: Schritt 2, Bild 1 von 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: Schritt 2, Bild 2 von 2
    • Press On then press Start Sampling
    • Press Enter
  3. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: Schritt 3, Bild 1 von 3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: Schritt 3, Bild 2 von 3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: Schritt 3, Bild 3 von 3
    • Press the number of the bottle you want to sample on
    • Press Enter
    • LCD should now show which bottle it will take a sample in
  4. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: Schritt 4, Bild 1 von 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: Schritt 4, Bild 2 von 2
    • To enable autonomous mode, flip switch to "Node Trigger Mode"
    • LCD should turn off
    • If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
Abschluss
Now the sampler is ready to be triggered remotely by an open-storm sensor node.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Brandon Wong
502 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 410
