Einleitung
If your mousepad is working incorrectly, refer to this page's troubleshooting guide. This fix is only necessary after you have attempted the prerequisite fixes.
Was du brauchst
Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
With a metal spudger, remove the plastic cover to unveil the final screw.
With the J1 Phillips head bit, remove remaining 60 mm screw.
With a metal spudger, pry apart the bottom cover working around the edges.
With tweezers, disconnect the USB/Audio circuit board cable.
Place the bottom cover off to the side.
With tweezers, disconnect the keyboard cable
With tweezers, disconnect the touchpad cable.
With the Philips #00 Screwdriver, loosen the 4 - M2 x 2mm screws
Gently remove the mouse touchpad.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
