Einleitung
Make sure to be careful you keep track of which screws you are using and which screws go where when disassembling. There are different types of screws used- one type being the screws used to separate the plastic shell and the other used to unscrew the scroll wheel itself.
Was du brauchst
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Gently remove the top plastic plate of the mouse.
Unplug the white cord from the circuit board.
Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
Use your thumbs to pop the scroll wheel out from its plastic frame.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
