Zum Hauptinhalt wechseln
Hoover LiNX The Motherboard Inside The Handle Replacement
Was du brauchst
  1. Hoover LiNX The Motherboard Inside The Handle  Replacement, Hoover LiNX Handle Teardown: Schritt 1, Bild 1 von 1
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 2, Bild 1 von 1
    • Remove the handle by pulling it up.
  3. Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 3, Bild 1 von 1
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 4, Bild 1 von 2 Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 5, Bild 1 von 2 Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 5, Bild 2 von 2
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 6, Bild 1 von 2 Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 6, Bild 2 von 2
    • Remove the silver plastic cover using the plastic opening tool.
  7. Hoover LiNX The Motherboard Inside The Handle  Replacement, The Motherboard Inside The Handle: Schritt 7, Bild 1 von 1
    • Remove the black rubber cover from the motherboard.
  8. Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 8, Bild 1 von 1
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 9, Bild 1 von 2 Hoover LiNX The Motherboard Inside The Handle  Replacement: Schritt 9, Bild 2 von 2
    • Carefully pull the motherboard out with its attached wires.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sara Vlhova
541 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S7-G4, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 888
