Einleitung
This guide will show you how to open dissemble the handle and replace the motherboard. You might need to do this if the device has power but fails to turn on. Remember to remove the battery from the device.
Was du brauchst
Remove the single 15mm Phillips #1 screw from the handle.
Remove the black rubber cover from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
