Zum Hauptinhalt wechseln
Dell Alienware 18 Memory Module Replacement
Was du brauchst
  1. Dell Alienware 18 Memory Module Replacement, Warning: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Memory Module Replacement, Removing the Memory Module: Schritt 2, Bild 1 von 1
    • To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
    • To remove memory module(s) from connectors DIMM1 and DIMM2: Remove the palm rest. See"Removing the Palm Rest" on page 39.
  3. Dell Alienware 18 Memory Module Replacement, Popping up the Memory Module: Schritt 3, Bild 1 von 1
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Dell Alienware 18 Memory Module Replacement, Removing the Memory Module: Schritt 4, Bild 1 von 1
    • Remove the memory module from the memory-module connector.
  5. Dell Alienware 18 Memory Module Replacement, Replacing the Memory Module: Schritt 5, Bild 1 von 1
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Dell Alienware 18 Memory Module Replacement, Securing the Memory Module: Schritt 6, Bild 1 von 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
darrius
5.213 Reputation
30 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 348
