Zum Hauptinhalt wechseln
Dell Alienware 18 Hard Drive Replacement
Was du brauchst
  1. Dell Alienware 18 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Disconnect the hard-drive cable from its connector on the system board.
  2. Dell Alienware 18 Hard Drive Replacement, Loosen the Screws: Schritt 2, Bild 1 von 1
    • Loosen the captive screws that secure the hard-drive assembly to the computer base.
  3. Dell Alienware 18 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Alienware 18 Hard Drive Replacement, Disconnecting the Interposer: Schritt 4, Bild 1 von 2 Dell Alienware 18 Hard Drive Replacement, Disconnecting the Interposer: Schritt 4, Bild 2 von 2
    • Disconnect the interposer from the hard drives.
    • NOTE: Your computer supports up to three drives.
  5. Dell Alienware 18 Hard Drive Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
    • Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
  6. Dell Alienware 18 Hard Drive Replacement, Placing the Hard-Drive: Schritt 6, Bild 1 von 1
    • Place the NEW primary hard drive in the hard-drive bracket.
  7. Dell Alienware 18 Hard Drive Replacement, Sliding the Secondary Hard-Drive: Schritt 7, Bild 1 von 1
    • If applicable, slide the secondary hard drive into the hard-drive bracket.
  8. Dell Alienware 18 Hard Drive Replacement, Secure the Screws: Schritt 8, Bild 1 von 1
    • Replace the screws that secure the primary hard drive to the hard-drive bracket.
  9. Dell Alienware 18 Hard Drive Replacement, Replace the Screws: Schritt 9, Bild 1 von 1
    • If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
  10. Dell Alienware 18 Hard Drive Replacement, Connecting the Interposer: Schritt 10, Bild 1 von 1
    • Connect the interposer to the hard drives.
  11. Dell Alienware 18 Hard Drive Replacement, Placing the Hard-Drive Assembly: Schritt 11, Bild 1 von 1
    • Place the hard-drive assembly in the computer base.
  12. Dell Alienware 18 Hard Drive Replacement, Tightening the Screws: Schritt 12, Bild 1 von 1
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  13. Dell Alienware 18 Hard Drive Replacement, Connecting the Hard-Drive: Schritt 13, Bild 1 von 1
    • Connect the hard-drive cable to its connector on the system board.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
darrius
5.213 Reputation
30 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 24
Insgesamt: 778
