Zum Hauptinhalt wechseln
Dell Alienware 18 Coin-Cell Battery Replacement
Was du brauchst
  1. Dell Alienware 18 Coin-Cell Battery Replacement, Before You Begin: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Coin-Cell Battery Replacement, Remove the base cover screws: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Coin-Cell Battery Replacement, Slide the Cover: Schritt 3, Bild 1 von 1
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery: Schritt 4, Bild 1 von 1
    • WARNING: The battery may explode if installed incorrectly. Replace the battery only with the same or equivalent type. Discard used batteries according to the manufacturer’s instructions.
    • CAUTION: Removing the coin-cell battery resets the BIOS settings to default. It is recommended that you note the BIOS settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from its connector on the system board.
  5. Dell Alienware 18 Coin-Cell Battery Replacement, Removing the Coin-Cell Battery: Schritt 5, Bild 1 von 1
    • Remove the coin-cell battery cable from the routing guides on the computer base.
  6. Dell Alienware 18 Coin-Cell Battery Replacement, Prying the Coin-Cell Battery: Schritt 6, Bild 1 von 1
    • Pry up the coin-cell battery from the slot on the system board.
  7. Dell Alienware 18 Coin-Cell Battery Replacement, Placing Coin-Cell Battery: Schritt 7, Bild 1 von 1
    • Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
  8. Dell Alienware 18 Coin-Cell Battery Replacement, Routing the Coin-Cell Battery Cable: Schritt 8, Bild 1 von 1
    • Route the coin-cell battery cable through the routing guides on the computer base.
  9. Dell Alienware 18 Coin-Cell Battery Replacement, Connecting Coin-Cell Battery: Schritt 9, Bild 1 von 1
    • Connect the coin-cell battery cable to its connector on the system board.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
darrius
5.213 Reputation
30 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 439
