Zum Hauptinhalt wechseln
Panasonic Lumix DMC-ZS6 Top Assembly Replacement
Was du brauchst
  1. Panasonic Lumix DMC-ZS6 Top Assembly Replacement, Top Assembly: Schritt 1, Bild 1 von 1
    • Remove the battery and the SD card.
  2. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 2, Bild 1 von 3 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 2, Bild 2 von 3 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 2, Bild 3 von 3
    • Remove the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Remove the two 1.0 mm screws on the left with a Phillips #000 screwdriver.
    • Remove the two 1.0 mm screws on the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 3, Bild 1 von 1
    • Carefully separate the back of the camera from the main body.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 4, Bild 1 von 2 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 4, Bild 2 von 2
    • Use the tip of a spudger to flip up the black tabs on the ribbon cables.
    • Pull the ribbon cables gently to unseat them.
  5. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 5, Bild 1 von 3 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 5, Bild 2 von 3 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 5, Bild 3 von 3
    • Remove one 1.0 mm screw from the bottom with a Phillips #000 screwdriver.
  6. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 6, Bild 1 von 1
    • Carefully separate the front of the camera from the main body.
  7. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 7, Bild 1 von 2 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 7, Bild 2 von 2
    • Use the tip of the spudger to disengage the plastic tab.
    • Carefully lift the selector switch away from the motherboard.
  8. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 8, Bild 1 von 2 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 8, Bild 2 von 2
    • Remove three 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the spudger to disengage the metal tab. Carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 9, Bild 1 von 1
    • Insert the tip of the spudger into the center hole of the tripod mount. Apply force in the direction facing away from the button.
    • Carefully lift the tripod mount out of the camera body.
  10. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 10, Bild 1 von 2 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 10, Bild 2 von 2
    • Use the spudger to flip up the brown tab on the motherboard. Carefully unseat the ribbon cable.
    • Insert the tip of the spudger into the hole on the daughterboard. Apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 11, Bild 1 von 3 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 11, Bild 2 von 3 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 11, Bild 3 von 3
    • Use the spudger to flip up the two tabs on the motherboard. Carefully unseat the ribbon cables.
    • Use the Phillips #000 screwdriver to remove the three silver screws.
    • Carefully lift the lens assembly out of the camera.
  12. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 12, Bild 1 von 3 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 12, Bild 2 von 3 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: Schritt 12, Bild 3 von 3
    • Use the tip of the spudger to disengage the tab on the back of the camera.
    • Use the tip of the spudger to disengage the two tabs on the front of the camera.
    • Carefully lift the top assembly out of place.
Abschluss
Derrick Thompson
1.035 Reputation
5 Anleitungen geschrieben
Baylor, Team S2-G5, Johnson Spring 2018 Mitglied von Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 260
