Zum Hauptinhalt wechseln
Alienware M11x Power-Button Board Replacement
Was du brauchst
  1. Alienware M11x Power-Button Board Replacement, Removing the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the power button board to the palm rest assembly.
  2. Alienware M11x Power-Button Board Replacement, Lifting the Power Button Board: Schritt 2, Bild 1 von 1
    • Lift the power button board off the palm rest assembly.
  3. Alienware M11x Power-Button Board Replacement, Removing the Screws: Schritt 3, Bild 1 von 1
    • Place the power button board on the palm rest assembly and replace the two screws that secure the power button board to the palm rest assembly.
    • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage the computer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
darrius
5.213 Reputation
30 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 341
