Einleitung
RAM or Random Access Memory, is a type of memory that temporarily stores information. If you have a faulty RAM or you are upgrading it, this guide will help you replace it.
Was du brauchst
Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
Using a plastic opening tool, gently pry the bottom cover from the laptop.
Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Just 1 slot :-(
Hello,
I need help.
My yoga 260 does not have any slot and I already bought a 16gb ddr4
