Einleitung
This guide explains how to remove the Hard Drive from the HP 15-f009wm notebook computer. This could be done to either replace a corrupt Hard Drive or to upgrade to a larger Hard Drive.
Was du brauchst
Flip the release switch.
Once the flip is switched, the battery should pop out.
Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
Remove the single 4mm Phillips #1 screw from the Wi-Fi card.
Pull the Wi-Fi card out of the motherboard.
Open the laptop.
Use a plastic opening tool to pop out the keyboard by starting at the top and working your way around the perimeter.
Open the screen up until it lays flat and rotate the laptop until the screen is closest to you.
Lift the keyboard from the laptop.
Use a spudger to lift up the black latch on the ZIF connector and remove the ribbon cable.
Use a spudger to lift the black tabs on the ZIF connectors.
Remove the ribbon cables from the ZIF connectors.
Use a plastic opening tool to pop the palm rest off of the laptop.
Lift and remove the palm rest.
Use a spudger to lift up the black latch on the ZIF connector.
Remove the USB/AUX port ribbon cable from the ZIF connector on the motherboard.
Remove the single 7mm Phillips #1 screw from the USB/AUX board.
Remove the USB/AUX board from the laptop.
Lift the Hard Drive from the laptop.
Disconnect the hard drive from the motherboard.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
This guide helped me so much with my laptop, thanks m8
Hello, i have a question. How much of capacity and technology i could use to upgrade my hard drive?
