Einleitung
If your Altec Lansing Mini Lifejacket 2's speaker is damaged or faulty, use the following step-by-step guide to replace it. This guide applies to both the speakers.
Was du brauchst
Use the spudger to remove the eight black pins from the front and back of the wire screens.
Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
Slide the mounting plate out to remove it.
Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
Where can I get this speaker parts?
