Zum Hauptinhalt wechseln
Altec Lansing Mini Lifejacket 2 Motherboard Replacement
Was du brauchst
  1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 2, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 2, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 3, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 4, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 4, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 5, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 6, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 9, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 9, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: Schritt 10, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: Schritt 10, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: Schritt 10, Bild 3 von 3
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
  11. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: Schritt 11, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: Schritt 11, Bild 3 von 3
    • Unplug the remaining four wire harnesses attached to the circuit board
  12. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 12, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the three 9.1mm Phillips #1 screws located on the circuit board.
  13. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 13, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 13, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Remove the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Stephen Albrecht
1.008 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S3-G2, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Mitglieder
6 Kommentare
I own the IMW778-BLU-TA model. Where can I find a replacement motherboard for it??
Nick Cote - Antwort
same for me, anyone knows where can I find a replacement of the motherboard? thx
Travis - Antwort
need back panel replacement
rahul pande - Antwort
Same here! Loved the product. Can not afford to buy something else.
Mr Shopper - Antwort
I need 2 the board for charging,usb,aux cord that plugs into motherboard.
John Proffit - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 5,359
