Einleitung
Use this guide to replace the motherboard in your Altec Lansing Mini Lifejacket 2 if the bluetooth chip, microphone, or another electronic component has failed.
Was du brauchst
Use the spudger to remove the eight black pins from the front and back of the wire screens.
Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
Slide the mounting plate out to remove it.
Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
Unplug the remaining four wire harnesses attached to the circuit board
2 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
need back panel replacement
Same here! Loved the product. Can not afford to buy something else.
I need 2 the board for charging,usb,aux cord that plugs into motherboard.
