Zum Hauptinhalt wechseln
DBPOWER T20 Lens Replacement
Was du brauchst
  1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: Schritt 1, Bild 1 von 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Lens Replacement: Schritt 2, Bild 1 von 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lens Replacement: Schritt 3, Bild 1 von 3 DBPOWER T20 Lens Replacement: Schritt 3, Bild 2 von 3 DBPOWER T20 Lens Replacement: Schritt 3, Bild 3 von 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lens Replacement: Schritt 4, Bild 1 von 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lens Replacement: Schritt 5, Bild 1 von 2 DBPOWER T20 Lens Replacement: Schritt 5, Bild 2 von 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lens Replacement: Schritt 6, Bild 1 von 3 DBPOWER T20 Lens Replacement: Schritt 6, Bild 2 von 3 DBPOWER T20 Lens Replacement: Schritt 6, Bild 3 von 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lens Replacement: Schritt 7, Bild 1 von 2 DBPOWER T20 Lens Replacement: Schritt 7, Bild 2 von 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lens Replacement: Schritt 8, Bild 1 von 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lens Replacement: Schritt 9, Bild 1 von 2 DBPOWER T20 Lens Replacement: Schritt 9, Bild 2 von 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lens Replacement: Schritt 10, Bild 1 von 2 DBPOWER T20 Lens Replacement: Schritt 10, Bild 2 von 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lens Replacement, Lens: Schritt 11, Bild 1 von 1
    • The lamp does not need to be removed for this step to be preformed.
  12. DBPOWER T20 Lens Replacement: Schritt 12, Bild 1 von 1
    • Detach the keystone adjuster from the lens housing.
    • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
  13. DBPOWER T20 Lens Replacement: Schritt 13, Bild 1 von 1
    • Remove the rubber foot and warranty sticker found underneath the device.
  14. DBPOWER T20 Lens Replacement: Schritt 14, Bild 1 von 2 DBPOWER T20 Lens Replacement: Schritt 14, Bild 2 von 2
    • Remove the two screws on the bottom of the device with a J0 screwdriver.
  15. DBPOWER T20 Lens Replacement: Schritt 15, Bild 1 von 1
    • Remove the focus-adjustment ring from the lens housing.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S16-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Mitglieder
5 Anleitungen geschrieben
3 Kommentare
How does the lens parts go together?
Lay - Antwort
I need to know the same
Tremaine Mullins - Antwort
Trying to put my lens back how to install
David Williams - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 31
Insgesamt: 2,287
