Einleitung
If the fan isn't working properly, the laptop can overheat. This guide will show users how to replace the fan.
Was du brauchst
Push the tabs on the left and right of the battery out towards the edge of the case.
While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
