Zum Hauptinhalt wechseln
HP Stream 13-c010nr Charging Port Replacement
Was du brauchst
  1. HP Stream 13-c010nr Charging Port Replacement, HP Stream 13-c010nr Disassembly: Schritt 1, Bild 1 von 1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Charging Port Replacement: Schritt 2, Bild 1 von 2 HP Stream 13-c010nr Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Charging Port Replacement: Schritt 3, Bild 1 von 2 HP Stream 13-c010nr Charging Port Replacement: Schritt 3, Bild 2 von 2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Charging Port Replacement, Charging Port: Schritt 5, Bild 1 von 1
    • Disconnect the charging port from the motherboard.
  6. HP Stream 13-c010nr Charging Port Replacement: Schritt 6, Bild 1 von 2 HP Stream 13-c010nr Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 5mm Phillips screws from the charging port.
    • Remove the bracket.
    • Pull out the charging port.
Abschluss
Keegan Lapham
759 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S1-G3, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 495
