Einleitung
This guide will teach you how to replace the USB Ports on the HP Stream 13-c010nr.
Was du brauchst
Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
Flip the laptop over and open it up.
Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
Lift up the keyboard.
Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
Pull up the ribbon cables from their sockets.
Use a spudger to flip up the retaining flap on the USB port ribbon cable ZIF socket.
Pull the ribbon cable out of the socket.
Remove the three 3mm Phillips #0 screws from the USB port.
Pull out the USB port.
