Zum Hauptinhalt wechseln
Lenovo IdeaPad N580 Battery Replacement
  1. Lenovo IdeaPad N580 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Lenovo IdeaPad N580 Battery Replacement: Schritt 2, Bild 1 von 1
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Lenovo IdeaPad N580 Battery Replacement: Schritt 3, Bild 1 von 1
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. Lenovo IdeaPad N580 Battery Replacement: Schritt 4, Bild 1 von 1
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
Abschluss
Alex Amorim
907 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S5-G2, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S5-G2, Peak Spring 2018
UMASSD-PEAK-S18S5G2
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 317
