Einleitung
If the device isn't powering on, then the issue may be due to the battery. Follow these steps to replace the battery.
Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
Take your free hand and place it on the battery. Gently slide it away from its slot.
