Zum Hauptinhalt wechseln
HP ProBook 455 G1 Motherboard Replacement
Was du brauchst
  1. HP ProBook 455 G1 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP ProBook 455 G1 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 Motherboard Replacement, Service Panel: Schritt 4, Bild 1 von 1
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 Motherboard Replacement: Schritt 5, Bild 1 von 2 HP ProBook 455 G1 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 Motherboard Replacement, Hard Drive: Schritt 6, Bild 1 von 2 HP ProBook 455 G1 Motherboard Replacement, Hard Drive: Schritt 6, Bild 2 von 2
    • Using a Phillips #0 Screwdriver, remove the four Phillips 3 mm screws that secure the hard drive into the computer.
  7. HP ProBook 455 G1 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pull the hard drive cover tab to the left in order to disconnect the hard drive from the computer.
  8. HP ProBook 455 G1 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Finally, using the same tab, lift the hard drive out of the hard drive port.
  9. HP ProBook 455 G1 Motherboard Replacement, DVD/CD Drive: Schritt 9, Bild 1 von 2 HP ProBook 455 G1 Motherboard Replacement, DVD/CD Drive: Schritt 9, Bild 2 von 2
    • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
    • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
    • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
  10. HP ProBook 455 G1 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
  11. HP ProBook 455 G1 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
  12. HP ProBook 455 G1 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use the tweezers to remove the six rubber stops on the side edges of the laptop.
    • These stops are covering six additional screws that need to be removed.
  13. HP ProBook 455 G1 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Using the Torx T8 screwdriver, remove the 13 Torx 6 millimeter screws on the bottom frame of the laptop.
    • Using the Phillips P0 screwdriver, remove the 2 Phillips 6 millimeter screws on the bottom frame of the laptop.
    • The 2 Phillips 6 millimeter screws can be identified by the small keyboard logo nearby.
    • Remove the 2 Phillips 3 millimeter screws from the edge of the frame where the optical drive was previously located.
    • Remove the 5 Phillips 3 millimeter screws from the area where the battery was previously located.
    • The Torx screwdriver is the screwdriver with a six-pointed star shaped tip. T8 refers to the name/size of this particular Torx head screwdriver.
  14. HP ProBook 455 G1 Motherboard Replacement: Schritt 14, Bild 1 von 2 HP ProBook 455 G1 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Reposition the computer so that it is upright and opened toward you.
    • Take the keyboard and slide it slightly towards you so it is disengaged from the top cover.
  15. HP ProBook 455 G1 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Lift the keyboard slowly, at an angle.
  16. HP ProBook 455 G1 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Disconnect the keyboard ribbon by carefully lifting the thin, black connector latch and separating the keyboard from the rest of the laptop.
  17. HP ProBook 455 G1 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Using the Torx T8 screwdriver, remove the 4 Torx 6 millimeter screws that are underneath the keyboard.
  18. HP ProBook 455 G1 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Disconnect the 3 ribbons from the motherboard by carefully lifting the thin, black connector latches and taking the cable out of its connecting slot.
    • Disconnect the small connector from the motherboard by sliding it out of it's port.
    • The ribbons are the strips of thin material with either blue or purple ends.
  19. HP ProBook 455 G1 Motherboard Replacement: Schritt 19, Bild 1 von 2 HP ProBook 455 G1 Motherboard Replacement: Schritt 19, Bild 2 von 2
    • Using a plastic opening tool, slowly and carefully detach the top cover from the bottom frame.
    • Do not do this step too fast or forcefully as there is a hidden cable connected between the two frames.
    • Make sure all of the screws mentioned in the previous steps have been removed. If some screws remain, the frames will not separate.
  20. HP ProBook 455 G1 Motherboard Replacement: Schritt 20, Bild 1 von 2 HP ProBook 455 G1 Motherboard Replacement: Schritt 20, Bild 2 von 2
    • Carefully disconnect that hidden ribbon from the motherboard.
    • After the ribbon is disconnected, fully separate the the two pieces and position the laptop upright, in front of you again.
  21. HP ProBook 455 G1 Motherboard Replacement: Schritt 21, Bild 1 von 1
    • Remove the 3 Phillips 4 millimeter screws that secure the motherboard and DVD/CD drive extension board to the laptop frame.
    • Remove the 2 Phillips 4 millimeter screws that secure the battery connecting port to the laptop frame.
  22. HP ProBook 455 G1 Motherboard Replacement: Schritt 22, Bild 1 von 1
    • Disconnect the ribbon attached to the motherboard
  23. HP ProBook 455 G1 Motherboard Replacement: Schritt 23, Bild 1 von 2 HP ProBook 455 G1 Motherboard Replacement: Schritt 23, Bild 2 von 2
    • Lift the right side of the motherboard up at an angle.
    • Continue to pull the motherboard up and toward the right to fully separate it from the laptop.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Baylor, Team S5-G1, Williams Spring 2018 Mitglied von Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 1,985
