Einleitung
In this guide, we will show you how to remove and replace the Display Assembly.
Was du brauchst
Disconnect the Mini-Card antenna cables from the Mini-Card(s).
Remove the two screws (one on each side) that secure the display assembly to the computer base.
Lift and remove the display assembly off the computer base.
Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
Connect the display cable to the system board connector.
Route the Mini-Card antenna cables through the routing guides on the computer base.
Connect the Mini-Card antenna cables to the Mini-Card(s).
