Einleitung
If you notice your laptop is overheating, then this guide may be able to help. This guide will show you how to replace the fan in a few steps.
Was du brauchst
Close the computer display and turn the computer over so that the base of the computer is facing up.
Remove the ten screws that secure the base cover to the base of the computer.
Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
Remove the battery.
Pry open the two clips.
Gently lift the RAM stick and pull it out of the motherboard.
Unplug the daughterboard cable in two places, then remove the daughterboard.
Unplug the fan cable.
Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
Remove the cooling fan from the laptop.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
