Zum Hauptinhalt wechseln
HP Compaq 515 Keyboard Replacement
Was du brauchst
  1. HP Compaq 515 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Turn the laptop over, the screws for the keyboard are in the middle and left of the device
  2. HP Compaq 515 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the two 0.725 cm Screws with a PH1 screwdriver bit
    • Make sure to put the screws in a safe place so you don't lose them
  3. HP Compaq 515 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Flip the laptop over and open the screen
  4. HP Compaq 515 Keyboard Replacement: Schritt 4, Bild 1 von 2 HP Compaq 515 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Gently use a plastic spudger to remove the plastic holder at the top of the keyboard
  5. HP Compaq 515 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Gently use a plastic spudger to remove the keyboard from its holders
    • Be careful as there is a wire connecting the keyboard to the laptop
  6. HP Compaq 515 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Carefully unclip and remove the large black wire that is connecting the keyboard to the laptop
Abschluss
Kirsten Harnden
259 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S4-G1, Covino Spring 2018 Mitglied von UMass Dartmouth, Team S4-G1, Covino Spring 2018
UMASSD-COVINO-S18S4G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 355
