Einleitung
This guide will help you to remove your broken RAM and replace it with a new one. Since the RAM is frequently updated to ensure top performance, the RAM is very easy to replace.
Was du brauchst
Close the laptop lid and flip it over so that Toshiba logo is facing down.
Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Evenly press down on the clips on either side of the RAM stick.
To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
I’ve got this exact model. Stock 6GB of RAM. However, I’ve attempted to upgrade to 8GB and have tried multiple sticks of RAM and no matter what, the computer won’t recognize it. I’ve ensured it’s locked in properly, RAM is functional, even factory reset. All to no success. Any ideas?
