Einleitung
This guide will help you replace the wireless card if it is not functioning adequately. It will instruct you to remove the cover to the wifi to gain access to the card and then replace it.
Was du brauchst
Close the laptop lid and flip it over so that Toshiba logo is facing down.
Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Remove the tape from the card.
Disconnect the wires using the #4 black spudger tool.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
