Einleitung
This guide will help you replace a broken motherboard in your laptop. It is a detailed process but this guide will allow you to easily remove and replace your motherboard.
Was du brauchst
Close the laptop lid and flip it over so that Toshiba logo is facing down.
Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Evenly press down on the clips on either side of the RAM stick.
To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
Remove the tape from the card.
Disconnect the wires using the #4 black spudger tool.
Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
Gently pull the CD drive out, disconnecting it from the motherboard connector marked in blue.
Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
Unscrew the two 3mm Phillips head screws on each fan using the Phillips #00 screwdriver.
Unscrew the four, 3mm Phillips head screws holding the last piece to the laptop using a Phillips #00 screwdriver.
Gently pull the cooling fan with heat sink off the laptop and set aside.
Disconnect all of the ribbons by lifting the tabs and gently pulling them out.
Remove all seven of the 3mm Phillips head screws with the Phillips #00 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
