Einleitung
This guide will help you remove the back panel of your device. No special skills are required, but you do need to know how to use a Phillips #00 screwdriver.
Was du brauchst
Close the laptop lid and flip it over so that Toshiba logo is facing down.
Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
