Zum Hauptinhalt wechseln
Dell Inspiron 13 N3010 Battery Replacement
Was du brauchst
  1. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Lock Latch: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Turn the computer over.
    • Slide the battery lock latch to the unlock position.
  2. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Release Latch: Schritt 2, Bild 1 von 1
    • Slide the battery release latch to the side.
  3. Dell Inspiron 13 N3010 Battery Replacement, Lifting the Battery: Schritt 3, Bild 1 von 1
    • Slide and lift the battery out of the battery bay.
  4. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery: Schritt 4, Bild 1 von 1
    • Slide the NEW battery into the battery bay, until it clicks into place.
  5. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Lock Latch: Schritt 5, Bild 1 von 1
    • Slide the battery lock latch to the lock position.
Abschluss
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 168
