Zum Hauptinhalt wechseln
Dell Vostro 1700 RAM Replacement
Was du brauchst
  1. Dell Vostro 1700 RAM Replacement, Keyboard: Schritt 1, Bild 1 von 3 Dell Vostro 1700 RAM Replacement, Keyboard: Schritt 1, Bild 2 von 3 Dell Vostro 1700 RAM Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Dell Vostro 1700 RAM Replacement: Schritt 2, Bild 1 von 1
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Dell Vostro 1700 RAM Replacement: Schritt 3, Bild 1 von 2 Dell Vostro 1700 RAM Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 3mm Phillips #0 screws.
  4. Dell Vostro 1700 RAM Replacement: Schritt 4, Bild 1 von 2 Dell Vostro 1700 RAM Replacement: Schritt 4, Bild 2 von 2
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  5. Dell Vostro 1700 RAM Replacement: Schritt 5, Bild 1 von 2 Dell Vostro 1700 RAM Replacement: Schritt 5, Bild 2 von 2
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
  6. Dell Vostro 1700 RAM Replacement, RAM: Schritt 6, Bild 1 von 3 Dell Vostro 1700 RAM Replacement, RAM: Schritt 6, Bild 2 von 3 Dell Vostro 1700 RAM Replacement, RAM: Schritt 6, Bild 3 von 3
    • Dislodge the RAM from its slot.
    • Push the retaining clips outward with your fingers.
  7. Dell Vostro 1700 RAM Replacement: Schritt 7, Bild 1 von 3 Dell Vostro 1700 RAM Replacement: Schritt 7, Bild 2 von 3 Dell Vostro 1700 RAM Replacement: Schritt 7, Bild 3 von 3
    • Pull the RAM chip up and out.
  8. Dell Vostro 1700 RAM Replacement: Schritt 8, Bild 1 von 3 Dell Vostro 1700 RAM Replacement: Schritt 8, Bild 2 von 3 Dell Vostro 1700 RAM Replacement: Schritt 8, Bild 3 von 3
    • Flip the laptop so under side is facing upwards.
    • Remove the 4.5mm Phillips #1 screw from the RAM cover.
    • Lift off the cover.
  9. Dell Vostro 1700 RAM Replacement: Schritt 9, Bild 1 von 2 Dell Vostro 1700 RAM Replacement: Schritt 9, Bild 2 von 2
    • Dislodge the RAM from its slot by pushing outwards on the retaining clips.
  10. Dell Vostro 1700 RAM Replacement: Schritt 10, Bild 1 von 3 Dell Vostro 1700 RAM Replacement: Schritt 10, Bild 2 von 3 Dell Vostro 1700 RAM Replacement: Schritt 10, Bild 3 von 3
    • Lift the RAM chip up and out of the slot.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nathan Valm
735 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G1, Peak Spring 2018
UMASSD-PEAK-S18S3G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,009
