Zum Hauptinhalt wechseln
How to Clean the Fan on a Toshiba TDP-XP2
Was du brauchst
  1. How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: Schritt 1, Bild 1 von 2 How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: Schritt 1, Bild 2 von 2
    • Remove the two screws from the bottom plate as shown.
  2. How to Clean the Fan on a Toshiba TDP-XP2: Schritt 2, Bild 1 von 1
    • Remove the two screws on the bulb housing.
  3. How to Clean the Fan on a Toshiba TDP-XP2: Schritt 3, Bild 1 von 1
    • Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out.
  4. How to Clean the Fan on a Toshiba TDP-XP2: Schritt 4, Bild 1 von 1
    • Using a can of compressed air, blow on the fan until all dust is gone.
    • Oil can be added in with a dropper on the bearing if needed.
Abschluss
Bryan Underwood
697 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 409
