Zum Hauptinhalt wechseln
Sony Xperia XA Back Cover Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Sony Xperia XA Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Back Cover Replacement: Schritt 3, Bild 1 von 3 Sony Xperia XA Back Cover Replacement: Schritt 3, Bild 2 von 3 Sony Xperia XA Back Cover Replacement: Schritt 3, Bild 3 von 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Back Cover Replacement: Schritt 4, Bild 1 von 3 Sony Xperia XA Back Cover Replacement: Schritt 4, Bild 2 von 3 Sony Xperia XA Back Cover Replacement: Schritt 4, Bild 3 von 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Back Cover Replacement: Schritt 6, Bild 1 von 1
    • Peel back the RAF antenna.
Abschluss
Cal Poly, Team S17-G2, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 61
