Einleitung
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
Was du brauchst
Stick the small suction cup on the bottom half of the back surface of the phone.
With the bottom of the device facing you, lift up on the suction cup handle.
Use the plastic opening tool around all sides to pry off the back cover.
Pry up the copper connector next to the battery with the plastic opening tool.
Pry up the black camera case with the plastic opening tool and then remove the case.
Pop off the small connector on the right side of the motherboard with the plastic opening tool.
Use the spudger to take off the connector in the top right of the motherboard.
Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
Peel back the tab past the connector.
Use the spudger to loosen the black connector from the top right of the motherboard.
Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
Use the spudger to separate the motherboard from the frame.
Pull out the motherboard using your fingers.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
