Zum Hauptinhalt wechseln
Sony Xperia XA Motherboard Replacement
Was du brauchst
  1. Sony Xperia XA Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Motherboard Replacement: Schritt 3, Bild 1 von 3 Sony Xperia XA Motherboard Replacement: Schritt 3, Bild 2 von 3 Sony Xperia XA Motherboard Replacement: Schritt 3, Bild 3 von 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Motherboard Replacement: Schritt 4, Bild 1 von 3 Sony Xperia XA Motherboard Replacement: Schritt 4, Bild 2 von 3 Sony Xperia XA Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 Sony Xperia XA Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Pry up the copper connector next to the battery with the plastic opening tool.
  8. Sony Xperia XA Motherboard Replacement: Schritt 8, Bild 1 von 2 Sony Xperia XA Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
  9. Sony Xperia XA Motherboard Replacement: Schritt 9, Bild 1 von 3 Sony Xperia XA Motherboard Replacement: Schritt 9, Bild 2 von 3 Sony Xperia XA Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  10. Sony Xperia XA Motherboard Replacement: Schritt 10, Bild 1 von 2 Sony Xperia XA Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
  11. Sony Xperia XA Motherboard Replacement: Schritt 11, Bild 1 von 2 Sony Xperia XA Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Use the spudger to take off the connector in the top right of the motherboard.
  12. Sony Xperia XA Motherboard Replacement: Schritt 12, Bild 1 von 3 Sony Xperia XA Motherboard Replacement: Schritt 12, Bild 2 von 3 Sony Xperia XA Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  13. Sony Xperia XA Motherboard Replacement: Schritt 13, Bild 1 von 3 Sony Xperia XA Motherboard Replacement: Schritt 13, Bild 2 von 3 Sony Xperia XA Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  14. Sony Xperia XA Motherboard Replacement: Schritt 14, Bild 1 von 2 Sony Xperia XA Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Use the spudger to loosen the black connector from the top right of the motherboard.
  15. Sony Xperia XA Motherboard Replacement: Schritt 15, Bild 1 von 3 Sony Xperia XA Motherboard Replacement: Schritt 15, Bild 2 von 3 Sony Xperia XA Motherboard Replacement: Schritt 15, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Pull out the square shaped connector using tweezers.
  16. Sony Xperia XA Motherboard Replacement: Schritt 16, Bild 1 von 2 Sony Xperia XA Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
  17. Sony Xperia XA Motherboard Replacement: Schritt 17, Bild 1 von 3 Sony Xperia XA Motherboard Replacement: Schritt 17, Bild 2 von 3 Sony Xperia XA Motherboard Replacement: Schritt 17, Bild 3 von 3
    • Use the spudger to separate the motherboard from the frame.
    • Pull out the motherboard using your fingers.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S17-G2, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 20
Insgesamt: 2,370
