Zum Hauptinhalt wechseln
Disassembling Yamaha YPG-225 Faceplate
Was du brauchst
  1. Disassembling Yamaha YPG-225 Faceplate, Batteries: Schritt 1, Bild 1 von 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Disassembling Yamaha YPG-225 Faceplate: Schritt 2, Bild 1 von 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Disassembling Yamaha YPG-225 Faceplate: Schritt 3, Bild 1 von 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Disassembling Yamaha YPG-225 Faceplate, Faceplate: Schritt 4, Bild 1 von 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Disassembling Yamaha YPG-225 Faceplate: Schritt 5, Bild 1 von 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Disassembling Yamaha YPG-225 Faceplate: Schritt 6, Bild 1 von 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Disassembling Yamaha YPG-225 Faceplate: Schritt 7, Bild 1 von 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Disassembling Yamaha YPG-225 Faceplate: Schritt 8, Bild 1 von 2 Disassembling Yamaha YPG-225 Faceplate: Schritt 8, Bild 2 von 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
Abschluss
Cal Poly, Team 2-62, Propen Fall 2012 Mitglied von Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 1,663
