Einleitung
Use this guide to separate the back panel from the display screen of your Asus Tablet MeMo Pad 7 ME7000C. Make sure you are using the proper tools and exercising caution while opening the back panel to avoid causing damage to the tablet.
Was du brauchst
Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
