Zum Hauptinhalt wechseln
Revlon 473 Hair Dryer Switch Replacement
Was du brauchst
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: Schritt 1, Bild 1 von 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: Schritt 2, Bild 1 von 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: Schritt 3, Bild 1 von 3 Revlon 473 Hair Dryer Switch Replacement: Schritt 3, Bild 2 von 3 Revlon 473 Hair Dryer Switch Replacement: Schritt 3, Bild 3 von 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: Schritt 4, Bild 1 von 1
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: Schritt 5, Bild 1 von 1
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: Schritt 6, Bild 1 von 1
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jessica Leyva
143 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 1-5, Propen Fall 2012 Mitglied von Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 1,816
